Ana içeriğe geç
Lenovo ThinkPad X390 Touchpad Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X390 Touchpad Replacement, Back Cover: adım 1, 1 resimden 1.
    • Turn off and power down the laptop before proceeding with the guide.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
    • The screws are not removable.
  2. Lenovo ThinkPad X390 Touchpad Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad X390 Touchpad Replacement: adım 2, 2 resimden 2.
    • Remove the base cover by inserting a plastic opening tool in between the cover and the rest of the laptop.
    • Once the tool is inserted, slide the tool along the edges of the case and push down on the opening tool to detach the case.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo ThinkPad X390 Touchpad Replacement, Battery: adım 3, 2 resimden 1. Lenovo ThinkPad X390 Touchpad Replacement, Battery: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, unplug the battery from the laptops motherboard by pulling on the cable that attaches it.
  4. Lenovo ThinkPad X390 Touchpad Replacement: adım 4, 2 resimden 1. Lenovo ThinkPad X390 Touchpad Replacement: adım 4, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the four 5.2 mm screws holding the battery in place.
  5. Lenovo ThinkPad X390 Touchpad Replacement: adım 5, 2 resimden 1. Lenovo ThinkPad X390 Touchpad Replacement: adım 5, 2 resimden 2.
    • Using your hands, remove the battery from the laptop.
  6. Lenovo ThinkPad X390 Touchpad Replacement, Touchpad: adım 6, 2 resimden 1. Lenovo ThinkPad X390 Touchpad Replacement, Touchpad: adım 6, 2 resimden 2.
    • After removing the battery, disconnect the trackpad from the laptop's motherboard
    • Using a plastic spudger, flip up the black plastic cover to release the cable.
    • Use a finger to hold back the cable to make accessing the connection easier.
  7. Lenovo ThinkPad X390 Touchpad Replacement: adım 7, 1 resimden 1.
    • Using a Phillips #0 screwdriver, unscrew the four 2.0 mm screws securing the touchpad to the device.
  8. Lenovo ThinkPad X390 Touchpad Replacement: adım 8, 1 resimden 1.
    • Lift up the bottom portion of the laptop and remove the trackpad.
Sonuç
Curtis Kubacka
261 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 5-1, Hunter Fall 2021 Clemson, Team 5-1, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S5G1
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 53
Her zaman: 1,585
