Ana içeriğe geç
Lenovo ThinkPad X61 Battery Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X61 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • The first step to replacing your insufficient battery is to flip your device to the back side, with the battery on top.
    • You should then find the battery lock release located in the top left corner, as indicated in the image.
  2. Lenovo ThinkPad X61 Battery Replacement: adım 2, 1 resimden 1.
    • The next step is to simply move the switch from the locked position to the unlocked position.
  3. Lenovo ThinkPad X61 Battery Replacement: adım 3, 1 resimden 1.
    • Next, you find the second lock release switch located under the bottom right of the battery holder as marked in the image.
    • Simply move the switch over from the locked position to the unlocked position and pull the battery from its holder. You can now insert the new battery.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ryan McCarthy
772 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 1,132
