Ana içeriğe geç
Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement, SSD: adım 1, 1 resimden 1.
    • Start by putting on your anti static wrist strap and connecting it to a stationary and stable object, like a desk.
    • This safety strap serves as a precaution to prevent any electrical static you might have on your body from transferring to the laptop's internal components and damaging the hardware.
    • Reminder to have this safety strap on you at all times during the process
  2. Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement: adım 2, 3 resimden 3.
    • Use a T5 Torx screwdriver to loosen and remove all eight bottom cover screws.
    • If you're having issues removing the back cover of the case, be sure to use the opening pick to pry the case open carefully.
  3. Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement: adım 3, 2 resimden 2.
    • Locate the SSD on your device and remove the 2.3 mm screw using a Phillips #00 screwdriver.
    • Place the loose screw somewhere safe and store for reassembly.
  4. Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement: adım 4, 3 resimden 3.
    • Pull the SSD out of its slot in the motherboard. It might require to wiggle it a little.
Sonuç
David Beltran Heredia
229 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team 11-11, Gonzalez Spring 2024 Gateway, Team 11-11, Gonzalez Spring 2024 üyesi
GCC-GONZALEZ-S24S11G11
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 53
