Ana içeriğe geç
Lenovo ThinkPad Yoga 11e Gen 6 Battery Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad Yoga 11e Gen 6 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Wearing the anti-static wrist strap will prevent a static shock from damaging the components in the laptop.
    • Disconnect the laptop from power and make sure it is completely powered off.
    • Turn the laptop facing down.
    • Loosen the eight captive screws using a JIS #0 screwdriver.
    • The screws are attached to the panel and cannot be removed.
    • Use a spudger to release the tabs securing the back case and carefully remove the panel.
  2. Lenovo ThinkPad Yoga 11e Gen 6 Battery Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad Yoga 11e Gen 6 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the three 4.5 mm screws from the battery using a JIS #0 screwdriver.
    • Lift the battery, then use your fingernail to slide the connector out of its socket.
    • Remove the battery.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 45
Her zaman: 152
