Ana içeriğe geç
Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement, Screen: adım 1, 2 resimden 1. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Wearing the anti-static wrist strap will prevent a static shock from damaging the components in the laptop.
    • Disconnect the laptop from power and make sure it is completely powered off.
    • Turn the laptop facing down.
    • Loosen the eight captive screws using a JIS #0 screwdriver.
    • The screws are attached to the panel and cannot be removed.
    • Carefully remove the panel.
  2. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: adım 2, 3 resimden 3.
    • Carefully disconnect the two sliding connectors in the left and right corner.
    • Disconnect the sliding connector on the Wi-Fi board.
    • Loosen the four 9.7 mm screws on the hinges in the top left and right corners using a Phillips #0 screwdriver.
    • Carefully lift the closest part of the laptop away from the screen side of the laptop.
  3. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: adım 3, 3 resimden 3.
    • Using tweezers, gently pry and remove the covers on the LCD strip.
    • Remove the two 3.3 mm screws that were previously under the covers on the LCD strip using a Phillips #0 screwdriver.
    • Carefully lift and remove the LCD strip.
  4. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: adım 4, 3 resimden 3.
    • Remove the two 3.3 mm screws from the silver panels using a Phillips #0 screwdriver.
    • Remove the two 3.3 mm screws from the LCD panel using a Phillips #0 screwdriver.
    • Carefully lift the screen towards you. You may use the spudger to assist lifting the screen. There will be one more connector on the side of the screen.
    • Carefully remove the ribbon connectors by gently pulling with your fingers.
Sonuç
Lex
509 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 52
Her zaman: 136
