Ana içeriğe geç
Lenovo ThinkPad Yoga 11e Gen 6 Wi-Fi Board Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad Yoga 11e Gen 6 Wi-Fi Board Replacement, Battery: adım 1, 1 resimden 1.
    • Wearing the anti-static wrist strap will prevent a static shock from damaging the components in the laptop.
    • Disconnect the laptop from power and make sure it is completely powered off.
    • Turn the laptop facing down.
    • Loosen the eight captive screws using a JIS #0 screwdriver.
    • The screws are attached to the panel and cannot be removed.
    • Use a spudger to release the tabs securing the back case and carefully remove the panel.
  2. Lenovo ThinkPad Yoga 11e Gen 6 Wi-Fi Board Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad Yoga 11e Gen 6 Wi-Fi Board Replacement: adım 2, 2 resimden 2.
    • Remove the three 4.5 mm screws from the battery using a JIS #0 screwdriver.
    • Lift the battery, then use your fingernail to slide the connector out of its socket.
    • Remove the battery.
  3. Lenovo ThinkPad Yoga 11e Gen 6 Wi-Fi Board Replacement, Wi-Fi Board: adım 3, 2 resimden 1. Lenovo ThinkPad Yoga 11e Gen 6 Wi-Fi Board Replacement, Wi-Fi Board: adım 3, 2 resimden 2.
    • Push on alternating sides of the JST connector and pull straight away from the socket to disconnect the CMOS battery.
  4. Lenovo ThinkPad Yoga 11e Gen 6 Wi-Fi Board Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad Yoga 11e Gen 6 Wi-Fi Board Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad Yoga 11e Gen 6 Wi-Fi Board Replacement: adım 4, 3 resimden 3.
    • Lift the two wires and plastic piece away from the Wi-Fi board.
    • Remove the single 3 mm screw holding the Wi-Fi board in place using a Phillips #0 screwdriver.
    • Hold the sides of the Wi-Fi board and slide it out of the socket.
Sonuç
Lex
509 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 27
Her zaman: 82
