Ana içeriğe geç
Lenovo ThinkPad Yoga 260 Repair Battery Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad Yoga 260 Repair Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: adım 3, 2 resimden 2.
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: adım 4, 2 resimden 1. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: adım 4, 2 resimden 2.
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Repair Battery Replacement, Battery: adım 5, 3 resimden 1. Lenovo ThinkPad Yoga 260 Repair Battery Replacement, Battery: adım 5, 3 resimden 2. Lenovo ThinkPad Yoga 260 Repair Battery Replacement, Battery: adım 5, 3 resimden 3.
    • Fold back the plastic cover to access the battery connection.
    • Remove the battery connection using your two index fingers.
    • Gently separate the connectors.
  6. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: adım 6, 3 resimden 3.
    • Unscrew the two 1.3 mm Phillips #1 fasteners using a Phillips #1 screwdriver and set them aside.
    • Lift the battery free from its mounting and remove it.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Daniel Fernandez
963 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G3, Eyestone Spring 2018 USF Tampa, Team S2-G3, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S2G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 65
Her zaman: 7,363
