Ana içeriğe geç
Lenovo ThinkPad Yoga 260 Trackpad Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Back Cover: adım 1, 1 resimden 1.
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Trackpad Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad Yoga 260 Trackpad Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Trackpad Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad Yoga 260 Trackpad Replacement: adım 3, 2 resimden 2.
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Trackpad Replacement: adım 4, 2 resimden 1. Lenovo ThinkPad Yoga 260 Trackpad Replacement: adım 4, 2 resimden 2.
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Battery: adım 5, 3 resimden 1. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Battery: adım 5, 3 resimden 2. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Battery: adım 5, 3 resimden 3.
    • Fold back the plastic cover to access the battery connection.
    • Remove the battery connection using your two index fingers.
    • Gently separate the connectors.
  6. Lenovo ThinkPad Yoga 260 Trackpad Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad Yoga 260 Trackpad Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad Yoga 260 Trackpad Replacement: adım 6, 3 resimden 3.
    • Unscrew the two 1.3 mm Phillips #1 fasteners using a Phillips #1 screwdriver and set them aside.
    • Lift the battery free from its mounting and remove it.
  7. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Trackpad: adım 7, 3 resimden 1. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Trackpad: adım 7, 3 resimden 2. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Trackpad: adım 7, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove the four 1.3mm Philips #1 fasteners from the back of the trackpad and set them aside.
  8. Lenovo ThinkPad Yoga 260 Trackpad Replacement: adım 8, 2 resimden 1. Lenovo ThinkPad Yoga 260 Trackpad Replacement: adım 8, 2 resimden 2.
    • Using your index finger and thumb gently pull the blue tab located at the top of the trackpad back from the assembly.
  9. Lenovo ThinkPad Yoga 260 Trackpad Replacement: adım 9, 3 resimden 1. Lenovo ThinkPad Yoga 260 Trackpad Replacement: adım 9, 3 resimden 2. Lenovo ThinkPad Yoga 260 Trackpad Replacement: adım 9, 3 resimden 3.
    • Flip the device right side up.
    • Open the computer.
    • Gently lift the trackpad out of the computer assembly.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 1,321
