Giriş
If the trackpad for your Lenovo Thinkpad Yoga 260 (Model Number: 20FD002HUS) is defective or broken, this guide will carefully walk you through the steps to replace it.
If your trackpad is not as responsive as it once was, the mouse not synced with your movements, or the trackpad not operating as normal you may consider replacing the trackpad.
Before using this guide ensure the laptop is powered off, disconnected from external power sources, and you have the listed tools available for use.
Neye ihtiyacın var
Fold back the plastic cover to access the battery connection.
Remove the battery connection using your two index fingers.
Using a Phillips #1 screwdriver, remove the four 1.3mm Philips #1 fasteners from the back of the trackpad and set them aside.
3 farklı kişi bu kılavuzu tamamladı.
