Ana içeriğe geç
Lenovo ThinkPad Yoga 260 Wifi-Card Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Back Cover: adım 1, 1 resimden 1.
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: adım 3, 2 resimden 2.
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: adım 4, 2 resimden 1. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: adım 4, 2 resimden 2.
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: adım 5, 3 resimden 1. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: adım 5, 3 resimden 2. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: adım 5, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove the 1.3 mm screw and set it aside.
  6. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: adım 6, 2 resimden 1. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: adım 6, 2 resimden 2.
    • Carefully pull out the Wi-Fi card.
    • Be sure to pull laterally, not upwards.
  7. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: adım 7, 2 resimden 2.
    • Carefully disconnect the 2 cables from the WiFi-Card as indicated on the card label.
    • Set the Wifi-Card aside.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 887
