Ana içeriğe geç
Lenovo ThinkPad Yoga 370 Battery Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad Yoga 370 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set it aside.
  2. Lenovo ThinkPad Yoga 370 Battery Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad Yoga 370 Battery Replacement: adım 2, 2 resimden 2.
    • Using the Phillips #00 screwdriver unscrew the eight circled 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 Battery Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad Yoga 370 Battery Replacement: adım 3, 2 resimden 2.
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 Battery Replacement: adım 4, 2 resimden 1. Lenovo ThinkPad Yoga 370 Battery Replacement: adım 4, 2 resimden 2.
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 Battery Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad Yoga 370 Battery Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad Yoga 370 Battery Replacement: adım 5, 3 resimden 3.
    • With your fingers, fold back the plastic cover highlighted.
    • Using two fingers, gently remove the battery connectors.
  6. Lenovo ThinkPad Yoga 370 Battery Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad Yoga 370 Battery Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad Yoga 370 Battery Replacement: adım 6, 3 resimden 3.
    • Using the Phillips #00 screwdriver, remove the two 4mm screws.
    • Remove the battery.
    • Make sure to only replace with a battery that matches your computer, any other battery could ignite or explode.
Sonuç
Note: Due to the similarity of the devices, several of the pictures were used from the Lenovo ThinkPad Yoga 260 Battery Replacement Guide to show the specific components that were missing in the Yoga 370.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
There’s a procedure you must do before removing any of the screws- disable the battery!
Ben Rossington - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 76
Her zaman: 5,846
