Ana içeriğe geç
Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement, Battery: adım 1, 1 resimden 1.
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set it aside.
  2. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: adım 2, 2 resimden 2.
    • Using the Phillips #00 screwdriver unscrew the eight circled 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: adım 3, 2 resimden 2.
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: adım 4, 2 resimden 1. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: adım 4, 2 resimden 2.
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: adım 5, 3 resimden 3.
    • With your fingers, fold back the plastic cover highlighted.
    • Using two fingers, gently remove the battery connectors.
  6. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: adım 6, 3 resimden 3.
    • Using the Phillips #00 screwdriver, remove the two 4mm screws.
    • Remove the battery.
    • Make sure to only replace with a battery that matches your computer, any other battery could ignite or explode.
  7. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement, Fingerprint Reader: adım 7, 1 resimden 1.
    • Identify the fingerprint reader on the left side of the laptop.
  8. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • To disconnect the fingerprint reader from the motherboard, unlock the ZIF connector and pull it out using tweezers.
  9. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: adım 9, 2 resimden 1. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: adım 9, 2 resimden 2.
    • Remove the one 4 mm screw from the metal covering with the Phillips #00 screwdriver.
    • Remove the metal cover.
  10. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: adım 10, 1 resimden 1.
    • Using tweezers, remove the fingerprint reader from the inset.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 343
