Ana içeriğe geç
Lenovo ThinkPad Yoga 370 RAM Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad Yoga 370 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set it aside.
  2. Lenovo ThinkPad Yoga 370 RAM Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad Yoga 370 RAM Replacement: adım 2, 2 resimden 2.
    • Using the Phillips #00 screwdriver, unscrew the eight circled 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 RAM Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad Yoga 370 RAM Replacement: adım 3, 2 resimden 2.
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 RAM Replacement: adım 4, 2 resimden 1. Lenovo ThinkPad Yoga 370 RAM Replacement: adım 4, 2 resimden 2.
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 RAM Replacement: adım 5, 2 resimden 1. Lenovo ThinkPad Yoga 370 RAM Replacement: adım 5, 2 resimden 2.
    • Using your thumbs, push the RAM's mounting clips outward.
    • The module will pop up on its own.
  6. Lenovo ThinkPad Yoga 370 RAM Replacement: adım 6, 1 resimden 1.
    • Gently remove the RAM from the mounting.
Sonuç
Note: Due to the similarity of the devices, several of the pictures were used from the Lenovo ThinkPad Yoga 260 Battery Replacement Guide to show the specific components that were missing in the Yoga 370.
4 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 20
Son 30 gün: 76
Her zaman: 6,279
