Ana içeriğe geç
Lenovo ThinkPad Yoga 370 Screen Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad Yoga 370 Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Remove rubber plugs on the lower corners of the screen
    • Unscrew screws under the rubber plugs
  2. Lenovo ThinkPad Yoga 370 Screen Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad Yoga 370 Screen Replacement: adım 2, 2 resimden 2.
    • Remove the four 4 mm screws along the bottom of the display.
  3. Lenovo ThinkPad Yoga 370 Screen Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, remove the tape from the display cable below the screen.
  4. Lenovo ThinkPad Yoga 370 Screen Replacement: adım 4, 1 resimden 1.
    • Slide the screen downwards towards the keyboard.
    • Lift the screen slowly from the frame when the screen is slid down completely.
    • The screen is still attached to the computer, do not pull away from the laptop frame until a later step.
    • Flip the screen over and lay face down on the keyboard.
  5. Lenovo ThinkPad Yoga 370 Screen Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad Yoga 370 Screen Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad Yoga 370 Screen Replacement: adım 5, 3 resimden 3.
    • Peel the tape off from the back of the screen, connecting the display to the device.
    • Remove the screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
I strongly recommend to at least unplug the battery before replacing the screen. I fried a motherboard once by manipulating a screen ribbon while the battery was still plugged in.
You should always unplug the battery before working on a device anyway.
lululock - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 88
Her zaman: 2,299
