Ana içeriğe geç
Lenovo ThinkPad Yoga Fan Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad Yoga Fan Replacement, Battery: adım 1, 3 resimden 1. Lenovo ThinkPad Yoga Fan Replacement, Battery: adım 1, 3 resimden 2. Lenovo ThinkPad Yoga Fan Replacement, Battery: adım 1, 3 resimden 3.
    • Flip the laptop over so the bottom is facing you.
    • Remove the ten screws using a Phillips #1 screwdriver.
    • Using the plastic opening tool, pry the bottom cover off the laptop.
  2. Lenovo ThinkPad Yoga Fan Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad Yoga Fan Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad Yoga Fan Replacement: adım 2, 3 resimden 3.
    • Remove two screws from the battery using a Phillips #1 screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Remove the battery from the laptop.
  3. Lenovo ThinkPad Yoga Fan Replacement, Speakers: adım 3, 3 resimden 1. Lenovo ThinkPad Yoga Fan Replacement, Speakers: adım 3, 3 resimden 2. Lenovo ThinkPad Yoga Fan Replacement, Speakers: adım 3, 3 resimden 3.
    • Disconnect connectors. Use fingers to pinch and pull the connector out.
  4. Lenovo ThinkPad Yoga Fan Replacement, Fan: adım 4, 3 resimden 1. Lenovo ThinkPad Yoga Fan Replacement, Fan: adım 4, 3 resimden 2. Lenovo ThinkPad Yoga Fan Replacement, Fan: adım 4, 3 resimden 3.
    • Remove the two screws from the retainer for the ports using a Phillips #1 screwdriver.
    • Remove the nine screws from the motherboard using a Phillips #1 screwdriver.
    • Remove the four screws from the fan under the motherboard using a Phillips #1 screwdriver.
    • Remove the fan from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Craig
241 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 üyesi
UMASSD-GULBRANDSEN-F21S4G4
3 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 43
Her zaman: 728
