Ana içeriğe geç
Lenovo ThinkPad Yoga RAM Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad Yoga RAM Replacement, Battery: adım 1, 3 resimden 1. Lenovo ThinkPad Yoga RAM Replacement, Battery: adım 1, 3 resimden 2. Lenovo ThinkPad Yoga RAM Replacement, Battery: adım 1, 3 resimden 3.
    • Flip the laptop over so the bottom is facing you.
    • Remove the ten screws using a Phillips #1 screwdriver.
    • Using the plastic opening tool, pry the bottom cover off the laptop.
  2. Lenovo ThinkPad Yoga RAM Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad Yoga RAM Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad Yoga RAM Replacement: adım 2, 3 resimden 3.
    • Remove two screws from the battery using a Phillips #1 screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Remove the battery from the laptop.
  3. Lenovo ThinkPad Yoga RAM Replacement, RAM: adım 3, 3 resimden 1. Lenovo ThinkPad Yoga RAM Replacement, RAM: adım 3, 3 resimden 2. Lenovo ThinkPad Yoga RAM Replacement, RAM: adım 3, 3 resimden 3.
    • Remove nine screws from the motherboard with a Phillips #1 screwdriver.
    • Remove all ribbon cables attached to the motherboard.
    • Lift the motherboard out of the device.
  4. Lenovo ThinkPad Yoga RAM Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad Yoga RAM Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad Yoga RAM Replacement: adım 4, 3 resimden 3.
    • Desolder the RAM to replace it.
    • You may also opt to replace the entire motherboard if soldering is not an option.
Sonuç
Michael Nessralla
171 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 üyesi
UMASSD-GULBRANDSEN-F21S4G4
3 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 108
Her zaman: 2,198
