Ana içeriğe geç
Lenovo ThinkPad Yoga Screen Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad Yoga Screen Replacement, Battery: adım 1, 3 resimden 1. Lenovo ThinkPad Yoga Screen Replacement, Battery: adım 1, 3 resimden 2. Lenovo ThinkPad Yoga Screen Replacement, Battery: adım 1, 3 resimden 3.
    • Flip the laptop over so the bottom is facing you.
    • Remove the ten screws using a Phillips #1 screwdriver.
    • Using the plastic opening tool, pry the bottom cover off the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. Lenovo ThinkPad Yoga Screen Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad Yoga Screen Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad Yoga Screen Replacement: adım 2, 3 resimden 3.
    • Remove two screws from the battery using a Phillips #1 screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Remove the battery from the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. Lenovo ThinkPad Yoga Screen Replacement, Screen: adım 3, 3 resimden 1. Lenovo ThinkPad Yoga Screen Replacement, Screen: adım 3, 3 resimden 2. Lenovo ThinkPad Yoga Screen Replacement, Screen: adım 3, 3 resimden 3.
    • Remove two screws under the plastic covers on the front of the screen using a Phillips #0 screwdriver.
    • Pry the plastic cover off with a spudger.
    • Remove the two screws from underneath the cover using a Phillips #0 screwdriver.
    • Detach the screen connector from the rest of the laptop.
    FixBot'a Sor
    Yorum Ekle
  4. Lenovo ThinkPad Yoga Screen Replacement: adım 4, 1 resimden 1.
    • Remove the screen from the rest of the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Michael Nessralla
171 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 üyesi
UMASSD-GULBRANDSEN-F21S4G4
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 83
Her zaman: 4,390
