Ana içeriğe geç
Lenovo Thinkpad E540 Display Screen Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad E540 Display Screen Replacement, Battery: adım 1, 2 resimden 1. Lenovo Thinkpad E540 Display Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 Display Screen Replacement: adım 2, 1 resimden 1.
    • Remove the battery.
  3. Lenovo Thinkpad E540 Display Screen Replacement, Display Screen: adım 3, 1 resimden 1.
    • Remove the two stickers at the bottom corners for the screen to reveal the screws.
    • Remove the two 1mm Phillips #00 screws from underneath the stickers.
  4. Lenovo Thinkpad E540 Display Screen Replacement: adım 4, 1 resimden 1.
    • Slide your finger underneath the plastic and pry gently to release the clips around the display bezel.
  5. Lenovo Thinkpad E540 Display Screen Replacement: adım 5, 1 resimden 1.
    • Remove the six 1.3mm Phillips #00 screws from around the display.
  6. Lenovo Thinkpad E540 Display Screen Replacement: adım 6, 1 resimden 1.
    • Remove the plastic covering and six 1.3mm Phillips #00 screws from both sides of the display.
  7. Lenovo Thinkpad E540 Display Screen Replacement: adım 7, 3 resimden 1. Lenovo Thinkpad E540 Display Screen Replacement: adım 7, 3 resimden 2. Lenovo Thinkpad E540 Display Screen Replacement: adım 7, 3 resimden 3.
    • Remove the orange tape covering the display connector.
    • Disconnect the display's ribbon cable by lifting up the latch and flipping it over 180 degrees.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Timothy Sumner
1.052 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G5, Nance Spring 2018 USF Tampa, Team S2-G5, Nance Spring 2018 üyesi
USFT-NANCE-S18S2G5
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 54
Her zaman: 5,079
