Ana içeriğe geç
Lenovo Thinkpad E540 Fan Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad E540 Fan Replacement, Battery: adım 1, 2 resimden 1. Lenovo Thinkpad E540 Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 Fan Replacement: adım 2, 1 resimden 1.
    • Remove the battery.
  3. Lenovo Thinkpad E540 Fan Replacement, Disassembly of the Back Panel: adım 3, 1 resimden 1.
    • Remove the three 1.2mm Phillips #00 screws from the bottom panel.
  4. Lenovo Thinkpad E540 Fan Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool to pry off the bottom panel.
  5. Lenovo Thinkpad E540 Fan Replacement, Fan: adım 5, 1 resimden 1.
    • Heatsink and fan are connected. You have to remove both at the same time.
    • The heatsink and fan are found on the right side.
  6. Lenovo Thinkpad E540 Fan Replacement: adım 6, 1 resimden 1.
    • Remove the two 1mm Phillips #0 screws from the fan.
    • Unscrew the four 2mm Phillips s#0 screws from the heatsink.
    • The screws on the heatsink will stay attached to it.
  7. Lenovo Thinkpad E540 Fan Replacement: adım 7, 1 resimden 1.
    • To remove the heatsink and fan, pull the fan upwards and towards the center.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Timothy Sumner
1.052 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G5, Nance Spring 2018 USF Tampa, Team S2-G5, Nance Spring 2018 üyesi
USFT-NANCE-S18S2G5
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 23
Son 30 gün: 76
Her zaman: 3,059
