Ana içeriğe geç
Lenovo Thinkpad E540 Hard Drive Replacement
Neye ihtiyacın var
    1. Lenovo Thinkpad E540 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Lenovo Thinkpad E540 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
      • Push the battery release switches away from each other.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo Thinkpad E540 Hard Drive Replacement: adım 2, 1 resimden 1.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Lenovo Thinkpad E540 Hard Drive Replacement, Disassembly of the Back Panel: adım 3, 1 resimden 1.
      • Remove the three 1.2mm Phillips #00 screws from the bottom panel.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo Thinkpad E540 Hard Drive Replacement: adım 4, 1 resimden 1.
      • Use a plastic opening tool to pry off the bottom panel.
      FixBot'a Sor
      Yorum Ekle
    1. Lenovo Thinkpad E540 Hard Drive Replacement, Hard Drive: adım 5, 1 resimden 1.
      • Remove the four 1.2mm Phillips #0 screws from the hard drive.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo Thinkpad E540 Hard Drive Replacement: adım 6, 1 resimden 1.
      • Pull up on the hard drive to allow for removal.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo Thinkpad E540 Hard Drive Replacement: adım 7, 1 resimden 1.
      • Disconnect the hard drive and pull out to remove.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Timothy Sumner
1.052 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G5, Nance Spring 2018 USF Tampa, Team S2-G5, Nance Spring 2018 üyesi
USFT-NANCE-S18S2G5
4 Üyeler
96 adet Kılavuz yazıldı
1Rehber Yorum
Thanks for this invaluable and easy guide.
Is it possible to replace the hdd with an ssd for this model? If so, which ssd would fit this laptop’s hdd socket?
Many thanks in advance.
SKP - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 56
Her zaman: 6,463
