Ana içeriğe geç
Lenovo Thinkpad E540 Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad E540 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Lenovo Thinkpad E540 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Remove the battery.
  3. Lenovo Thinkpad E540 Hard Drive Replacement, Disassembly of the Back Panel: adım 3, 1 resimden 1.
    • Remove the three 1.2mm Phillips #00 screws from the bottom panel.
    For me a Phillips #1 was the first bit with a tight fit (testet PH #00, #0, #1).
    Till - Yanıt
  4. Lenovo Thinkpad E540 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool to pry off the bottom panel.
  5. Lenovo Thinkpad E540 Hard Drive Replacement, Hard Drive: adım 5, 1 resimden 1.
    • Remove the four 1.2mm Phillips #0 screws from the hard drive.
  6. Lenovo Thinkpad E540 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Pull up on the hard drive to allow for removal.
  7. Lenovo Thinkpad E540 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Disconnect the hard drive and pull out to remove.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Timothy Sumner
1.040 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G5, Nance Spring 2018 USF Tampa, Team S2-G5, Nance Spring 2018 üyesi
USFT-NANCE-S18S2G5
4 Üyeler
Bir Yorum
Thanks for this invaluable and easy guide.
Is it possible to replace the hdd with an ssd for this model? If so, which ssd would fit this laptop’s hdd socket?
Many thanks in advance.
SKP - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 22
Her zaman: 5,360
