Ana içeriğe geç
Lenovo Thinkpad E540 Keyboard Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad E540 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Lenovo Thinkpad E540 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 Keyboard Replacement: adım 2, 1 resimden 1.
    • Remove the battery.
  3. Lenovo Thinkpad E540 Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Push the keyboard forward towards the display to create a gap above the trackpad.
  4. Lenovo Thinkpad E540 Keyboard Replacement: adım 4, 1 resimden 1.
    • Remove the four 1mm Phillips #00 screws found hidden underneath the keys.
  5. Lenovo Thinkpad E540 Keyboard Replacement: adım 5, 1 resimden 1.
    • Tilt the keyboard forward from the top and lift gently.
    • Dont pull too far because there is a cable attached to the back.
  6. Lenovo Thinkpad E540 Keyboard Replacement: adım 6, 2 resimden 1. Lenovo Thinkpad E540 Keyboard Replacement: adım 6, 2 resimden 2.
    • Use a spudger to lift the black latch on the ZIF connectors.
    • Remove the blue and purple ribbon cables from the ZIF connectors.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Timothy Sumner
1.040 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G5, Nance Spring 2018 USF Tampa, Team S2-G5, Nance Spring 2018 üyesi
USFT-NANCE-S18S2G5
4 Üyeler
4 Yorum
Thank you for posting this guide. I was able to comfortably replace my keyboard on a Lenovo E540 Thinkpad after I spilled a full glass of water on it. I was able to get a replacement keyboard via AliExpress for $25.84USD -- I initially considered buying a replacement from eBay but the keyboard prices were half of the laptop's current value, which is a bit silly.
Thank you Timothy Sumner, you’re a legend! :)
Zeeshan Muhammad - Yanıt
These instructions are miserably wrong for the model E540 20C6-008SUS. The keyboard is completely covered by a plastic grid that fills the large gaps between the keys. The keyboard hold-down screws are hidden by this grid. YOUR OWN PHOTO CLEARLY SHOWS THIS ! Furthermore, the keyboard can not be pushed “forward towards the display to create a gap above the trackpad “ simply because the 4 screws are holding it solidly in place. This plastic grid must be carefully pried up and out to expose the keyboard screws enough to be able to get a screwdriver in position over the screw heads.
Hewey Dewey - Yanıt
With my edge 540 (submodel unknown) I was able to reach the screws by pushing the screw driver under the plastic grid. It did however slightly scuff up my F key
Dick van Zalinge -
You forgot the latch underneath the main battery.
Moose Technologies - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 10,213
