Ana içeriğe geç
Lenovo Thinkpad E540 WiFi Card Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad E540 WiFi Card Replacement, Battery: adım 1, 2 resimden 1. Lenovo Thinkpad E540 WiFi Card Replacement, Battery: adım 1, 2 resimden 2.
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 WiFi Card Replacement: adım 2, 1 resimden 1.
    • Remove the battery.
  3. Lenovo Thinkpad E540 WiFi Card Replacement, WiFi Card: adım 3, 1 resimden 1.
    • Remove the single 1mm Phillips #0 screw holding the small plastic panel in place.
  4. Lenovo Thinkpad E540 WiFi Card Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool to remove panel.
  5. Lenovo Thinkpad E540 WiFi Card Replacement: adım 5, 2 resimden 1. Lenovo Thinkpad E540 WiFi Card Replacement: adım 5, 2 resimden 2.
    • Disconnect the two antenna cables from the wifi card.
    • Remove the single 1mm Phillips #0 screw from the wifi card.
  6. Lenovo Thinkpad E540 WiFi Card Replacement: adım 6, 1 resimden 1.
    • Remove the wifi card by sliding it out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Timothy Sumner
1.040 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G5, Nance Spring 2018 USF Tampa, Team S2-G5, Nance Spring 2018 üyesi
USFT-NANCE-S18S2G5
4 Üyeler
2 Yorum
Pictures show battery is still connected to laptop.
Monte Christo - Yanıt
There appear to be several different wifi cards available, with different PN numbers. Is it necessary to replace with the exact same PN number? Can these wifi cards be upgraded?
Thomas - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 2,974
