Ana içeriğe geç
Lenovo Thinkpad T410i Speakers Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad T410i Speakers Replacement, Keyboard: adım 1, 1 resimden 1.
    • Remove the battery.
    • Unfortunately, the battery isn't pictured because our device did not come with a battery at the time of the creation of this guide.
  2. Lenovo Thinkpad T410i Speakers Replacement: adım 2, 2 resimden 1. Lenovo Thinkpad T410i Speakers Replacement: adım 2, 2 resimden 2.
    • Loosen (do not remove) the 14.0mm screw in the DIMM slot cover with a Phillips #2 screwdriver.
  3. Lenovo Thinkpad T410i Speakers Replacement: adım 3, 1 resimden 1.
    • Pry loose the top left key-covers with a plastic opening tool.
  4. Lenovo Thinkpad T410i Speakers Replacement: adım 4, 2 resimden 1. Lenovo Thinkpad T410i Speakers Replacement: adım 4, 2 resimden 2.
    • Nudge the plastic tabs around the keyboard using the plastic opening tool while lifting it with a spudger.
    • Ensure all 5 clips are loosened from the front of the keyboard before removing.
  5. Lenovo Thinkpad T410i Speakers Replacement: adım 5, 1 resimden 1.
    • Slowly raise keyboard away from the laptop. A short ribbon must be removed before keyboard is free.
    • Remove the keyboard from the device.
  6. Lenovo Thinkpad T410i Speakers Replacement, Speakers: adım 6, 1 resimden 1.
    • Remove the six 14.0mm screws with a Phillips #0 screwdriver.
    • Remove the three 3.0mm screws with a Phillips #0 screwdriver.
  7. Lenovo Thinkpad T410i Speakers Replacement: adım 7, 1 resimden 1.
    • Snap off the top cover with a plastic opening tool, ensuring that the tabs don't snap back on.
  8. Lenovo Thinkpad T410i Speakers Replacement: adım 8, 1 resimden 1.
    • Lift the top panel off of the device.
    • Lift the panel slowly in order to not damage the orange ribbon cable.
  9. Lenovo Thinkpad T410i Speakers Replacement: adım 9, 1 resimden 1.
    • Detach the ribbon cable as shown in the picture.
  10. Lenovo Thinkpad T410i Speakers Replacement: adım 10, 2 resimden 1. Lenovo Thinkpad T410i Speakers Replacement: adım 10, 2 resimden 2.
    • Remove the four 3.0mm screws with a Phillips #0 screwdriver.
  11. Lenovo Thinkpad T410i Speakers Replacement: adım 11, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using the Precision Tweezers, remove the speaker cable from the connector.
    • Remove the speaker from the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Gabriel Cordova
637 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Thompson Fall 2017 USF Tampa, Team S1-G2, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S1G2
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 33
Her zaman: 1,500
