Ana içeriğe geç
Lenovo Thinkpad T430 Fan and Heat Sink Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad T430 Fan and Heat Sink Replacement, Battery: adım 1, 2 resimden 1. Lenovo Thinkpad T430 Fan and Heat Sink Replacement, Battery: adım 1, 2 resimden 2.
    • Place the laptop so that the bottom is facing up.
    • Slide the battery unlock lever to the right.
    • Gently pull the battery outwards from the body of the device.
  2. Lenovo Thinkpad T430 Fan and Heat Sink Replacement, Keyboard: adım 2, 2 resimden 1. Lenovo Thinkpad T430 Fan and Heat Sink Replacement, Keyboard: adım 2, 2 resimden 2.
    • Remove the two screws that hold the RAM door in place using a Phillips #000 screwdriver.
    • Remove the back panel.
  3. Lenovo Thinkpad T430 Fan and Heat Sink Replacement: adım 3, 1 resimden 1.
    • Remove the two screws in the middle panel using a Phillips #000 screwdriver.
  4. Lenovo Thinkpad T430 Fan and Heat Sink Replacement: adım 4, 2 resimden 1. Lenovo Thinkpad T430 Fan and Heat Sink Replacement: adım 4, 2 resimden 2.
    • Flip the laptop over and open the lid.
    • Push the keyboard forward from the space bar while applying pressure to lift up the keyboard.
    • Carefully unplug and disconnect the ribbon cable.
    • Pulling too hard on the ribbon cable may cause damage to the device. Make sure to disconnect the ribbon cable before completely removing the keyboard.
  5. Lenovo Thinkpad T430 Fan and Heat Sink Replacement, Palm Rest: adım 5, 1 resimden 1.
    • Returning to the underside of the device, remove the six screws that hold the palm rest in place.
  6. Lenovo Thinkpad T430 Fan and Heat Sink Replacement: adım 6, 1 resimden 1.
    • Flipping to the front of the device, remove the two screws holding the palm rest in place.
  7. Lenovo Thinkpad T430 Fan and Heat Sink Replacement: adım 7, 2 resimden 1. Lenovo Thinkpad T430 Fan and Heat Sink Replacement: adım 7, 2 resimden 2.
    • With the top of the device facing you, tilt the device 45 degrees upward to access the clips that keep the palm rest in place.
    • Using a Jimmy, gently unclip the palm rest from the body of the device.
    • Starting from the hinge of the device, gently lift the palm rest from the body of the device. Before completely removing the palm rest, unclip the ribbon band underneath the mouse pad.
    • Pulling too hard on the ribbon band may cause damage to the device. Completely disconnect the ribbon band underneath the keyboard before separating the palm rest from the device.
  8. Lenovo Thinkpad T430 Fan and Heat Sink Replacement, Speakers: adım 8, 2 resimden 1. Lenovo Thinkpad T430 Fan and Heat Sink Replacement, Speakers: adım 8, 2 resimden 2.
    • Return to the front of the device.
    • Remove the screws holding each of the speakers in place on the left and right sides of the device.
    • Lift the speakers from the body of the device.
  9. Lenovo Thinkpad T430 Fan and Heat Sink Replacement, Fan and Heat Sink: adım 9, 2 resimden 1. Lenovo Thinkpad T430 Fan and Heat Sink Replacement, Fan and Heat Sink: adım 9, 2 resimden 2.
    • Remove the four screws holding the heat sink in place.
    • Unplug the fan cable.
    • Gently lift the heat sink from the body of the device.
Sonuç
Kristen Gismondi
92.843 İtibar
241 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.715 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 70
Her zaman: 201
