Neye ihtiyacın var
Flip the laptop over.
Place it on a flat, sturdy surface.
Remove the battery by moving the battery latch and slowly sliding the battery out.
Locate the drive enclosure.
Use a small Phillips screwdriver to unscrew the single screw that holds down the drive enclosure cover.
Insert a spudger (or a similar tool) under the loop of the black pull tab, and gently pull it out from above the hard drive.
Remove the plastic rails from the old drive and place them on the new drive.
37 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
If the pull tab is not present - probably due to the drive being replaced - it is possible with care to put the tip of a screwdriver into the rubber side rails and pull the unit out
