Ana içeriğe geç
Lenovo Thinkpad T430 Keyboard Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad T430 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Lenovo Thinkpad T430 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Place the laptop so that the bottom is facing up.
    • Slide the battery unlock lever to the right.
    • Gently pull the battery outwards from the body of the device.
  2. Lenovo Thinkpad T430 Keyboard Replacement, Keyboard: adım 2, 2 resimden 1. Lenovo Thinkpad T430 Keyboard Replacement, Keyboard: adım 2, 2 resimden 2.
    • Remove the two screws that hold the RAM door in place using a Phillips #000 screwdriver.
    • Remove the back panel.
  3. Lenovo Thinkpad T430 Keyboard Replacement: adım 3, 1 resimden 1.
    • Remove the two screws in the middle panel using a Phillips #000 screwdriver.
  4. Lenovo Thinkpad T430 Keyboard Replacement: adım 4, 2 resimden 1. Lenovo Thinkpad T430 Keyboard Replacement: adım 4, 2 resimden 2.
    • Flip the laptop over and open the lid.
    • Push the keyboard forward from the space bar while applying pressure to lift up the keyboard.
    • Carefully unplug and disconnect the ribbon cable.
    • Pulling too hard on the ribbon cable may cause damage to the device. Make sure to disconnect the ribbon cable before completely removing the keyboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jacob Ferreira
97 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-5, Konn Fall 2024 UMass Dartmouth, Team 1-5, Konn Fall 2024 üyesi
UMASSD-KONN-F24S1G5
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 65
Her zaman: 184
