Ana içeriğe geç
Lenovo Thinkpad T430 Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad T430 Motherboard Replacement, Battery: adım 1, 2 resimden 1. Lenovo Thinkpad T430 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Place the laptop so that the bottom is facing up.
    • Slide the battery unlock lever to the right.
    • Gently pull the battery outwards from the body of the device.
  2. Lenovo Thinkpad T430 Motherboard Replacement, Keyboard: adım 2, 2 resimden 1. Lenovo Thinkpad T430 Motherboard Replacement, Keyboard: adım 2, 2 resimden 2.
    • Remove the two screws that hold the RAM door in place using a Phillips #000 screwdriver.
    • Remove the back panel.
  3. Lenovo Thinkpad T430 Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the two screws in the middle panel using a Phillips #000 screwdriver.
  4. Lenovo Thinkpad T430 Motherboard Replacement: adım 4, 2 resimden 1. Lenovo Thinkpad T430 Motherboard Replacement: adım 4, 2 resimden 2.
    • Flip the laptop over and open the lid.
    • Push the keyboard forward from the space bar while applying pressure to lift up the keyboard.
    • Carefully unplug and disconnect the ribbon cable.
    • Pulling too hard on the ribbon cable may cause damage to the device. Make sure to disconnect the ribbon cable before completely removing the keyboard.
  5. Lenovo Thinkpad T430 Motherboard Replacement, Palm Rest: adım 5, 1 resimden 1.
    • Returning to the underside of the device, remove the six screws that hold the palm rest in place.
  6. Lenovo Thinkpad T430 Motherboard Replacement: adım 6, 1 resimden 1.
    • Flipping to the front of the device, remove the two screws holding the palm rest in place.
  7. Lenovo Thinkpad T430 Motherboard Replacement: adım 7, 2 resimden 1. Lenovo Thinkpad T430 Motherboard Replacement: adım 7, 2 resimden 2.
    • With the top of the device facing you, tilt the device 45 degrees upward to access the clips that keep the palm rest in place.
    • Using a Jimmy, gently unclip the palm rest from the body of the device.
    • Starting from the hinge of the device, gently lift the palm rest from the body of the device. Before completely removing the palm rest, unclip the ribbon band underneath the mouse pad.
    • Pulling too hard on the ribbon band may cause damage to the device. Completely disconnect the ribbon band underneath the keyboard before separating the palm rest from the device.
  8. Lenovo Thinkpad T430 Motherboard Replacement, Display Assembly: adım 8, 3 resimden 1. Lenovo Thinkpad T430 Motherboard Replacement, Display Assembly: adım 8, 3 resimden 2. Lenovo Thinkpad T430 Motherboard Replacement, Display Assembly: adım 8, 3 resimden 3.
    • Unclip the Wi-Fi cables (orange, white, and blue) from the body of the device by gently pulling up.
    • Remove the screw holding the video cable in place and remove the metal bracket to gain access to the video cable underneath.
    • Unplug the ribbon cable located on the right side of the device.
    • Gently unplug the video cable from the body of the device.
    • Remove the two screws holding the screen in place near the left and right hinges.
  9. Lenovo Thinkpad T430 Motherboard Replacement: adım 9, 1 resimden 1.
    • Flip the device over.
    • Remove the two screws from the upper corners of the laptop using a Phillips #000 screwdriver.
    • Lift the display assembly away from the rest of the device and set it aside.
  10. Lenovo Thinkpad T430 Motherboard Replacement, Speakers: adım 10, 2 resimden 1. Lenovo Thinkpad T430 Motherboard Replacement, Speakers: adım 10, 2 resimden 2.
    • Return to the front of the device.
    • Remove the screws holding each of the speakers in place on the left and right sides of the device.
    • Lift the speakers from the body of the device.
  11. Lenovo Thinkpad T430 Motherboard Replacement, Fan and Heat Sink: adım 11, 2 resimden 1. Lenovo Thinkpad T430 Motherboard Replacement, Fan and Heat Sink: adım 11, 2 resimden 2.
    • Remove the four screws holding the heat sink in place.
    • Unplug the fan cable.
    • Gently lift the heat sink from the body of the device.
  12. Lenovo Thinkpad T430 Motherboard Replacement, CPU: adım 12, 1 resimden 1.
    • Twist the screw holding the processor in place into the unlock position represented by an unlocked lock symbol.
    • Carefully lift the processor from the device.
    • Touching any of the processor's contacts may cause damage to the device. Be careful when removing the processor and store it in a safe place.
  13. Lenovo Thinkpad T430 Motherboard Replacement, Wi-Fi Card: adım 13, 1 resimden 1.
    • Remove the screw holding the wireless card in place and lift the card from the body of the device.
  14. Lenovo Thinkpad T430 Motherboard Replacement, Motherboard: adım 14, 1 resimden 1.
    • Unplug the motherboard power connector from the body of the device.
  15. Lenovo Thinkpad T430 Motherboard Replacement: adım 15, 1 resimden 1.
    • Remove the six screws that hold the bottom casing in place.
    • Remove the bottom casing from the rest of the device and set the casing aside.
  16. Lenovo Thinkpad T430 Motherboard Replacement: adım 16, 1 resimden 1.
    • Flip the device so the underside is facing upwards.
    • Remove the five screws holding the motherboard in place.
    • Remove the motherboard from the rest of the device and replace it.
Sonuç
Arthur Schlerman
364 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-5, Konn Fall 2024 UMass Dartmouth, Team 1-5, Konn Fall 2024 üyesi
UMASSD-KONN-F24S1G5
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 92
Her zaman: 289
