Ana içeriğe geç
Lenovo Thinkpad T430 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad T430 Wi-Fi Card Replacement, Battery: adım 1, 2 resimden 1. Lenovo Thinkpad T430 Wi-Fi Card Replacement, Battery: adım 1, 2 resimden 2.
    • Place the laptop so that the bottom is facing up.
    • Slide the battery unlock lever to the right.
    • Gently pull the battery outwards from the body of the device.
  2. Lenovo Thinkpad T430 Wi-Fi Card Replacement, Keyboard: adım 2, 2 resimden 1. Lenovo Thinkpad T430 Wi-Fi Card Replacement, Keyboard: adım 2, 2 resimden 2.
    • Remove the two screws that hold the RAM door in place using a Phillips #000 screwdriver.
    • Remove the back panel.
  3. Lenovo Thinkpad T430 Wi-Fi Card Replacement: adım 3, 1 resimden 1.
    • Remove the two screws in the middle panel using a Phillips #000 screwdriver.
  4. Lenovo Thinkpad T430 Wi-Fi Card Replacement: adım 4, 2 resimden 1. Lenovo Thinkpad T430 Wi-Fi Card Replacement: adım 4, 2 resimden 2.
    • Flip the laptop over and open the lid.
    • Push the keyboard forward from the space bar while applying pressure to lift up the keyboard.
    • Carefully unplug and disconnect the ribbon cable.
    • Pulling too hard on the ribbon cable may cause damage to the device. Make sure to disconnect the ribbon cable before completely removing the keyboard.
  5. Lenovo Thinkpad T430 Wi-Fi Card Replacement, Palm Rest: adım 5, 1 resimden 1.
    • Returning to the underside of the device, remove the six screws that hold the palm rest in place.
  6. Lenovo Thinkpad T430 Wi-Fi Card Replacement: adım 6, 1 resimden 1.
    • Flipping to the front of the device, remove the two screws holding the palm rest in place.
  7. Lenovo Thinkpad T430 Wi-Fi Card Replacement: adım 7, 2 resimden 1. Lenovo Thinkpad T430 Wi-Fi Card Replacement: adım 7, 2 resimden 2.
    • With the top of the device facing you, tilt the device 45 degrees upward to access the clips that keep the palm rest in place.
    • Using a Jimmy, gently unclip the palm rest from the body of the device.
    • Starting from the hinge of the device, gently lift the palm rest from the body of the device. Before completely removing the palm rest, unclip the ribbon band underneath the mouse pad.
    • Pulling too hard on the ribbon band may cause damage to the device. Completely disconnect the ribbon band underneath the keyboard before separating the palm rest from the device.
  8. Lenovo Thinkpad T430 Wi-Fi Card Replacement, Display Assembly: adım 8, 3 resimden 1. Lenovo Thinkpad T430 Wi-Fi Card Replacement, Display Assembly: adım 8, 3 resimden 2. Lenovo Thinkpad T430 Wi-Fi Card Replacement, Display Assembly: adım 8, 3 resimden 3.
    • Unclip the Wi-Fi cables (orange, white, and blue) from the body of the device by gently pulling up.
    • Remove the screw holding the video cable in place and remove the metal bracket to gain access to the video cable underneath.
    • Unplug the ribbon cable located on the right side of the device.
    • Gently unplug the video cable from the body of the device.
    • Remove the two screws holding the screen in place near the left and right hinges.
  9. Lenovo Thinkpad T430 Wi-Fi Card Replacement: adım 9, 1 resimden 1.
    • Flip the device over.
    • Remove the two screws from the upper corners of the laptop using a Phillips #000 screwdriver.
    • Lift the display assembly away from the rest of the device and set it aside.
  10. Lenovo Thinkpad T430 Wi-Fi Card Replacement, Wi-Fi Card: adım 10, 1 resimden 1.
    • Remove the screw holding the wireless card in place and lift the card from the body of the device.
Sonuç
Kristen Gismondi
92.837 İtibar
241 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 57
Her zaman: 168
