Ana içeriğe geç
Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Set to Maintenance Mode: adım 1, 1 resimden 1.
    • While booting, press the F1 button to enter the BIOS.
    • Go to "Config" and then to "Power".
    • Select "Disable Built-in Battery" and press Enter.
    • You will be asked to proceed. Select "Yes".
    • The laptop shuts down.Unplug the laptop from AC.
    • Remove the battery.
  2. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Front Bezel: adım 2, 3 resimden 1. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Front Bezel: adım 2, 3 resimden 2. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Front Bezel: adım 2, 3 resimden 3.
    • Start removing the front bezel in the lower display corners using a prying tool.
    • Make sure the glue and tape will stick to the front bezel instead of the display and rear bezel. You can use a gripping tool and a cutter for this.
  3. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Screws: adım 3, 2 resimden 1. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Screws: adım 3, 2 resimden 2.
    • Remove 4 screws M2XL3 with screwdriver.
  4. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Rear Bezel: adım 4, 2 resimden 1. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Rear Bezel: adım 4, 2 resimden 2.
    • Remove the rear bezel with the prying tool.
    • Make shure you do not move or damage the blue and black cable behind the bezel.
  5. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Release Display: adım 5, 3 resimden 1. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Release Display: adım 5, 3 resimden 2. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Release Display: adım 5, 3 resimden 3.
    • Carefully release the display, turn it around and place it on the keyboard.
    • Ensure to not damage the connector on the lower part of the display.
  6. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Release the Connector: adım 6, 2 resimden 1. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Release the Connector: adım 6, 2 resimden 2.
    • Remove the connector together with the label.
Sonuç
19 farklı kişi bu kılavuzu tamamladı.
Markus Schmidt
716 İtibar
1 Kılavuz yazıldı
7Kılavuz Yorumları
Did this upgrade with my T440 and worked great, used a LP140WF1 / B140HAN01 display added some much needed pixels and IPS viewing angles. I bought from Aliexpress Store: Kevin trade shop.
Ryan - Yanıt
What about T440s with touch panel?
TINGHUI WANG - Yanıt
I do not possess a touch device, sorry.
Markus Schmidt -
Can this be done as an upgrade
Randall Bickford - Yanıt
You mean from “normal” to touch display? I cannot comment on a touch device…
Markus Schmidt -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 22
Son 30 gün: 173
Her zaman: 32,250
