Giriş
Is your laptop heating up too quickly or making loud noises? Consider using this guide to replace the fan in your device.
Neye ihtiyacın var
Make sure to power down and turn off your device before proceeding with the repair.
Flip your laptop over so that the backside is facing you.
Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
+1 — Only the bottom left and right screws can be pulled out. Don’t try to force the others.
Use the Phillips #1 screwdriver to remove the four screws holding in the fan assembly.
Lift the fan out of it's compartment to gain access to the cable connection, firmly grab the cable and pull it out of it's housing.
La ventola del t440 è compatibile con il t440s?
sir ow to fix making noisi
6 farklı kişi bu kılavuzu tamamladı.
4 Yorum
What about thermal grease?
Useless info. This is the heatsink (with fan) replacement, NOT fan replacement. The poster is a moron.
Victor - The fan and heatsink are attached to one another. How would you propose one replace the fan only? If you have a method, please create your own guide if this one was authored by such a “moron”. Jeez.
You should also disable the internal battery in the BIOS first too.
martin8777 - Yanıt
