Ana içeriğe geç
Lenovo Thinkpad T440s Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad T440s Hard Drive Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo Thinkpad T440s Hard Drive Replacement, Back Panel: adım 1, 2 resimden 2.
    • Make sure to power down and turn off your device before proceeding with the repair.
    • Flip your laptop over so that the backside is facing you.
  2. Lenovo Thinkpad T440s Hard Drive Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
    • Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
  3. Lenovo Thinkpad T440s Hard Drive Replacement: adım 3, 2 resimden 1. Lenovo Thinkpad T440s Hard Drive Replacement: adım 3, 2 resimden 2.
    • Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
  4. Lenovo Thinkpad T440s Hard Drive Replacement: adım 4, 1 resimden 1.
    • Remove the back panel from the device.
  5. Lenovo Thinkpad T440s Hard Drive Replacement, Hard Drive: adım 5, 2 resimden 1. Lenovo Thinkpad T440s Hard Drive Replacement, Hard Drive: adım 5, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the single screw securing the hard drive.
  6. Lenovo Thinkpad T440s Hard Drive Replacement: adım 6, 1 resimden 1.
    • Use the metal spudger to lift the hard drive out of it's compartment.
  7. Lenovo Thinkpad T440s Hard Drive Replacement: adım 7, 2 resimden 1. Lenovo Thinkpad T440s Hard Drive Replacement: adım 7, 2 resimden 2.
    • Grab a hold of the hard drive and pull it straight out from the device.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Terelle Montalvo
1.477 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G5, Simcock Fall 2018 UMass Dartmouth, Team S1-G5, Simcock Fall 2018 üyesi
UMASSD-SIMCOCK-F18S1G5
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 78
Her zaman: 9,740
