Ana içeriğe geç
Lenovo Thinkpad T450s Bottom Panel Removal
Neye ihtiyacın var
  1. Lenovo Thinkpad T450s Bottom Panel Removal, Battery: adım 1, 2 resimden 1. Lenovo Thinkpad T450s Bottom Panel Removal, Battery: adım 1, 2 resimden 2.
    • Turn off device before starting
    • Flip the laptop upside down so you have access to the battery.
  2. Lenovo Thinkpad T450s Bottom Panel Removal: adım 2, 1 resimden 1.
    • Slide lock button 1 to the unlock position and gently slide away from your body.
  3. Lenovo Thinkpad T450s Bottom Panel Removal: adım 3, 2 resimden 1. Lenovo Thinkpad T450s Bottom Panel Removal: adım 3, 2 resimden 2.
    • Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
  4. Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: adım 4, 3 resimden 1. Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: adım 4, 3 resimden 2. Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: adım 4, 3 resimden 3.
    • Flip the device over and lay it down with the underside facing upwards.
    • Unscrew all 8 screws. While they should not come out completely, in some cases, the plastic retaining washers may come off of one or more of the screws, allowing them to come out completely. - should this happen, look for a loose, tiny black plastic washer once the case is open. It's possible, in some cases, to reattach the retaining washer.
  5. Lenovo Thinkpad T450s Bottom Panel Removal: adım 5, 2 resimden 1. Lenovo Thinkpad T450s Bottom Panel Removal: adım 5, 2 resimden 2.
    • Pry the bottom from the computer until it pops out.
    • In some cases, the vented side of the case may cling to the heat sink; appears to be adhesive. Take care when separating.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 47
Her zaman: 3,967
