Ana içeriğe geç
Lenovo Thinkpad T450s Keyboard Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad T450s Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Remove the battery by pulling on the two sliding buttons next to the battery.
  2. Lenovo Thinkpad T450s Keyboard Replacement: adım 2, 2 resimden 1. Lenovo Thinkpad T450s Keyboard Replacement: adım 2, 2 resimden 2.
    • Remove the seven 5mm screws on the back cover using the Phillips #0 screwdriver.
    There is no need to remove the back panel for a keyboard replacement on the T450s
    Daniel Hathorn - Yanıt
    Also, there are eight (8) screws: one is right under the battery.
    Fei Yeh - Yanıt
  3. Lenovo Thinkpad T450s Keyboard Replacement: adım 3, 1 resimden 1.
    • Remove the two rubber stoppers from where the battery previously was.
    This can be done without removing the back cover. Slightly more difficult but only by about 1mm or less.
    Fei Yeh - Yanıt
  4. Lenovo Thinkpad T450s Keyboard Replacement: adım 4, 2 resimden 1. Lenovo Thinkpad T450s Keyboard Replacement: adım 4, 2 resimden 2.
    • Flip the laptop, shift the keyboard upwards by applying force to the two indents on the keyboard.
    • Remove the six 5mm screws that are on the keyboard using the Phillips #0 screwdriver.
    • These screws are located above the left ctrl key, S, F, J, semicolon, and up arrow keys.
    Use a #00 screwdriver.
  5. Lenovo Thinkpad T450s Keyboard Replacement: adım 5, 1 resimden 1.
    • Lift the keyboard and flip over exposing the connection to the motherboard.
  6. Lenovo Thinkpad T450s Keyboard Replacement: adım 6, 1 resimden 1.
    • Remove the plastic covering and detach touch point and keyboard cable.
    There are TWO keyboard cables, one is hidden below the other, be careful not to yank it. To undo the cables, lift the black part up and away.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nathan Morgan
469 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G5, Stella Fall 2019 IUPUI, Team S2-G5, Stella Fall 2019 üyesi
IUPUI-STELLA-F19S2G5
3 Üyeler
1Rehber Yorum
If after replacement your keyboard has some keys clacking, make sure you slid the keyboard all the way back. Even a small amount can make some keys feel weird.
Ivan Veloz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 22
Son 30 gün: 105
Her zaman: 7,151
