Ana içeriğe geç
Lenovo Thinkpad T450s Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad T450s Motherboard Replacement, Fan: adım 1, 1 resimden 1.
    • Flip the laptop over so that the bottom is facing up.
    • Unlock the battery by sliding the keys outwards. When unlocked, push the battery forwards to remove.
  2. Lenovo Thinkpad T450s Motherboard Replacement: adım 2, 1 resimden 1.
    • Unscrew all 3.7 mm Phillips #0 screws from the back of the laptop. Half of them will remain attached to the cover.
    • Lift off the back cover.
  3. Lenovo Thinkpad T450s Motherboard Replacement: adım 3, 1 resimden 1.
    • Unscrew the four 5 mm Phillips #0 screws that secure the heatsink.
    • The screws will remain attached.
    • The Fan is attached to the heat sink assembly.
  4. Lenovo Thinkpad T450s Motherboard Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool or a nylon spudger to push the fan's bundled cable connector free.
    • Remove the fan and heat sink assembly from the motherboard.
  5. Lenovo Thinkpad T450s Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove all twelve 3.6 mm Phillips #00 screws.
  6. Lenovo Thinkpad T450s Motherboard Replacement, Remove the Hard Drive: adım 6, 2 resimden 1. Lenovo Thinkpad T450s Motherboard Replacement, Remove the Hard Drive: adım 6, 2 resimden 2.
    • Remove the hard drive from the motherboard's by gently pulling it out and up at the same time.
  7. Lenovo Thinkpad T450s Motherboard Replacement: adım 7, 1 resimden 1.
    • Pull out the socket that is attached to the left side of the battery case.
  8. Lenovo Thinkpad T450s Motherboard Replacement: adım 8, 1 resimden 1.
    • Unplug the cable that attaches the polymer battery to the motherboard by pulling it out carefully.
  9. Lenovo Thinkpad T450s Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove the ribbon cable attached to the the battery case carefully by pulling the cable up and out.
  10. Lenovo Thinkpad T450s Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the motherboard from the case. If the motherboard does not come off the case or feels stuck, make sure that you have removed all the cables prior
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Ekip
IUPUI, Team 2-3, Harley Spring 2022 IUPUI, Team 2-3, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S2G3
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 28
Her zaman: 1,682
