Ana içeriğe geç
Lenovo Thinkpad Tablet 1838 Touch Screen Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement, Touch Screen: adım 1, 1 resimden 1.
    • Remove the button with the arrow pointing left.
    • You can do this by putting the spudger underneath the button and pulling up.
  2. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: adım 2, 1 resimden 1.
    • Remove the two 10mm Phillips #00 screws.
  3. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: adım 3, 1 resimden 1.
    • Use an opening tool to pry open and disconnect the screen from the rest of the tablet.
    • Be gentle and work from the bottom of the tablet in counterclockwise direction.
  4. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: adım 4, 1 resimden 1.
    • Open the tablet screen to the left, making sure not to disconnect any of the wires connecting the screen to the tablet.
  5. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: adım 5, 2 resimden 1. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: adım 5, 2 resimden 2.
    • Disconnect the ribbon connector by pulling up on the white gate.
    • Then just simply pull the wire to the left to disconnect it.
  6. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: adım 6, 2 resimden 1. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: adım 6, 2 resimden 2.
    • Disconnect the last ribbon connector using your fingernails to grip the ends of the connector and gently pull to the left.
    • There might be some tape over the connector that you will have to remove.
  7. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: adım 7, 1 resimden 1.
    • You have successfully removed the old screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 783
