Giriş
This guide will help you remove the battery from your Lenovo Thinkpad Twist s230u. The battery provides power to the computer and can be recharged, but it can lose its capacity to hold charge over time. In rare cases, the battery can even be defective straight out of the box. Whatever the reason, if you need to replace your battery or you need to remove it for another replacement, this guide is for you. For more information on ways to fix problems you may have, visit our troubleshooting page.
Neye ihtiyacın var
Flip the laptop over.
Using a Phillips #1 Screwdriver, unscrew the screw on the bottom left corner.
Use a Philips #1 screwdriver to remove 2 screws on the bottom of the laptop.
Flip your device over.
Use the Phillips #1 screwdriver to remove the nine screws.
4 farklı kişi bu kılavuzu tamamladı.
