Ana içeriğe geç
Lenovo Thinkpad Twist s230u Upper Casing Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad Twist s230u Upper Casing Replacement, Hard Drive: adım 1, 2 resimden 1. Lenovo Thinkpad Twist s230u Upper Casing Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Flip the laptop over.
    • Using a Phillips #1 Screwdriver, unscrew the screw on the bottom left corner.
  2. Lenovo Thinkpad Twist s230u Upper Casing Replacement: adım 2, 1 resimden 1.
    • Using the iFixit Opening tool, loosen the hard drive cover.
  3. Lenovo Thinkpad Twist s230u Upper Casing Replacement: adım 3, 1 resimden 1.
    • Remove the hard drive cover.
  4. Lenovo Thinkpad Twist s230u Upper Casing Replacement: adım 4, 2 resimden 1. Lenovo Thinkpad Twist s230u Upper Casing Replacement: adım 4, 2 resimden 2.
    • Remove the hard drive by sliding it out.
  5. Lenovo Thinkpad Twist s230u Upper Casing Replacement, Keyboard: adım 5, 1 resimden 1.
    • Use a Philips #1 screwdriver to remove 2 screws on the bottom of the laptop.
  6. Lenovo Thinkpad Twist s230u Upper Casing Replacement: adım 6, 1 resimden 1.
    • Use a spudger to loosen the keyboard around the edges.
    • Carefully push the keyboard towards the screen to unlatch it.
    • Do not push too hard, as there are ribbon cables attached to the keyboard.
  7. Lenovo Thinkpad Twist s230u Upper Casing Replacement: adım 7, 1 resimden 1.
    • Carefully lift up the keyboard to access the wires underneath.
    • Be careful not to break the ribbon cables attached underneath.
  8. Lenovo Thinkpad Twist s230u Upper Casing Replacement: adım 8, 3 resimden 1. Lenovo Thinkpad Twist s230u Upper Casing Replacement: adım 8, 3 resimden 2. Lenovo Thinkpad Twist s230u Upper Casing Replacement: adım 8, 3 resimden 3.
    • Open the small black flap on each of the ribbon cables. It should lift with a slight effort.
    • Pull out the ribbon cables and remove the keyboard from the device.
  9. Lenovo Thinkpad Twist s230u Upper Casing Replacement, Upper Casing: adım 9, 1 resimden 1.
    • Flip your device over.
    • Use the Phillips #1 screwdriver to remove the nine screws.
  10. Lenovo Thinkpad Twist s230u Upper Casing Replacement: adım 10, 2 resimden 1. Lenovo Thinkpad Twist s230u Upper Casing Replacement: adım 10, 2 resimden 2.
    • Flip the device back over and open the top.
    • Use the Phillips #1 screwdriver to remove the seven silver screws.
    • Disconnect the three cables inside the case.
    • Lift up the brown tab and disconnect the ribbon cable.
  11. Lenovo Thinkpad Twist s230u Upper Casing Replacement: adım 11, 2 resimden 1. Lenovo Thinkpad Twist s230u Upper Casing Replacement: adım 11, 2 resimden 2.
    • Close the lid and turn the device around.
    • Use the iFixit Opening Tool to lift up and remove the tab on the back.
  12. Lenovo Thinkpad Twist s230u Upper Casing Replacement: adım 12, 2 resimden 1. Lenovo Thinkpad Twist s230u Upper Casing Replacement: adım 12, 2 resimden 2.
    • Turn the device back around and reopen it.
    • Use the iFixit Opening Tool to disconnect the top of the case from the bottom.
    • Lift up the top of the case and slide it out from under the screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 922
