Ana içeriğe geç
Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement, Bottom Panel: adım 1, 2 resimden 1. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement, Bottom Panel: adım 1, 2 resimden 2.
    • Unscrew the nine captive screws on the bottom cover of the laptop using a Phillips #1 screwdriver.
    • The screws do not fully come out of the back cover, so there is no need for screw management.
    • There are a few small clips around the edge that you may need to pry at to free them. An opening pick may be helpful for this process.
  2. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 2, 1 resimden 1.
    • Lift the back cover up and off of the computer.
  3. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement, Lithium Battery: adım 3, 3 resimden 1. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement, Lithium Battery: adım 3, 3 resimden 2. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement, Lithium Battery: adım 3, 3 resimden 3.
    • Carefully lift the far end of the battery connector with an opening tool facing towards you.
    • Remove the connector by pushing it forward and lifting.
  4. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 4, 2 resimden 1. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the central 5 mm screw with a Phillips #1 screwdriver.
  5. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 5, 1 resimden 1.
    • Lift the battery up and out of the computer.
  6. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement, Coin Cell Battery: adım 6, 2 resimden 1. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement, Coin Cell Battery: adım 6, 2 resimden 2.
    • Peel back the plastic protective cover above the main battery section to expose the coin-cell's red and black wires.
  7. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 7, 2 resimden 1. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 7, 2 resimden 2.
    • Gently unplug the coin-cell wires from the connector by pulling horizontally away from the connector.
    • Lift the coin cell out from the computer.
  8. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement, Speakers: adım 8, 3 resimden 1. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement, Speakers: adım 8, 3 resimden 2. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement, Speakers: adım 8, 3 resimden 3.
    • Carefully unplug the speaker connector by pulling it towards you.
  9. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 9, 2 resimden 1. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 9, 2 resimden 2.
    • Remove the two 5 mm screws on each speaker with a Phillips #1 screwdriver.
  10. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 10, 2 resimden 1. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 10, 2 resimden 2.
    • Unweave the blue and white wires from underneath the plastic tabs connected to the battery.
  11. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 11, 1 resimden 1.
    • Lift each speaker up and out from the computer.
  12. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement, Wireless LAN Card: adım 12, 2 resimden 1. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement, Wireless LAN Card: adım 12, 2 resimden 2.
    • Remove the protective film to the left of the fan assembly.
  13. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 13, 3 resimden 1. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 13, 3 resimden 2. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 13, 3 resimden 3.
    • Carefully disconnect the gray and black antenna connectors on the green wireless LAN card by lifting under the antennas with an opening tool.
  14. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove the 2.5 mm screw holding the card in place with a Phillips #1 screwdriver.
  15. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 15, 2 resimden 1. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 15, 2 resimden 2.
    • Carefully slide the wireless card out of the slot by pulling it to the right.
  16. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement, Cooling Fan: adım 16, 2 resimden 1. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement, Cooling Fan: adım 16, 2 resimden 2.
    • Peel off the black protective film to the left of the fan.
  17. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 17, 3 resimden 1. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 17, 3 resimden 2. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 17, 3 resimden 3.
    • Do not remove the four screws closest to the fan. They do not affect the fan assembly.
    • Disconnect the antenna wires on green the wireless LAN card to the left of the fan.
  18. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 18, 3 resimden 1. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 18, 3 resimden 2. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 18, 3 resimden 3.
    • Lift up the hinge connector that is attached to the fan's ribbon cable.
    • Carefully disconnect the cable by pulling outwards from the ribbon connector.
  19. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 19, 3 resimden 1. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 19, 3 resimden 2. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 19, 3 resimden 3.
    • Loosen the screws on the 'x' configuration of metal.
    • These screws are held on to the metal 'x', so don't worry about them falling out.
  20. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 20, 1 resimden 1.
    • Lift the fan upwards from the board.
  21. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 21, 1 resimden 1.
    • It's best practice to replace the old thermal paste under the 'x' configuration of metal. (Guides on how to replace thermal paste can be found here.)
  22. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement, Motherboard: adım 22, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the two 5 mm screws securing the USB ports on the righthand side of the motherboard.
  23. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 23, 2 resimden 1. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 23, 2 resimden 2.
    • The white triangle symbol on the motherboard identifies the longer 5mm length screws.
    • Using a Phillips #0 screwdriver, remove the five 5mm screws.
    • The white square symbol on the motherboard identifies 2mm length screws.
    • Using a Phillips #0 screwdriver, remove the four 2mm screws.
  24. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 24, 1 resimden 1.
    • Remove the 7 ribbon cables connecting the motherboard to their respective components by flipping up the locking black tabs with a spudger and pulling the cables from their connectors.
    • Remove the red and blue wires attached to the motherboard.
  25. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 25, 2 resimden 1. Lenovo Thinkpad X1 Carbon 4th Gen Motherboard Replacement: adım 25, 2 resimden 2.
    • Using the plastic opening tool, gently lift up on the motherboard.
    • If resistance is felt double check to make sure all the screws and ribbon cables are out.
    • Lift the motherboard out from the computer.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
good work, thank you
Hector Duzont - Yanıt
Step 9 (speakers) needs to be done before you can do Step 5 (main battery) as the battery is attached by tabs under the speaker screws. If you don't do this then you'll break off those battery tabs like I did!
Dunmail Nashe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 55
Her zaman: 3,418
