Ana içeriğe geç
Lenovo Thinkpad X201 Tablet RAM Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad X201 Tablet RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Remove the battery by sliding forward the switch here.
    • For more info on how to remove the battery, refer to battery replacement guide.
  2. Lenovo Thinkpad X201 Tablet RAM Replacement: adım 2, 1 resimden 1.
    • The RAM is the small square component on the back. Unscrew all screws using a diamond head screw.
    • There are only two screws to remove as circled here.
    • The screw head used here is a JIS J00 Driver.
  3. Lenovo Thinkpad X201 Tablet RAM Replacement: adım 3, 1 resimden 1.
    • On the edges of the RAM components, push each switch to the side.
    • The RAM chip should pop up on its own once you push each side outwards.
  4. Lenovo Thinkpad X201 Tablet RAM Replacement: adım 4, 2 resimden 1. Lenovo Thinkpad X201 Tablet RAM Replacement: adım 4, 2 resimden 2.
    • The RAM chip should pop up on its own once the sides are pushed outwards.
    • Gently pull on the RAM to remove.
  5. Lenovo Thinkpad X201 Tablet RAM Replacement: adım 5, 1 resimden 1.
    • Remove the RAM from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Peter Gachuki
666 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G7, Peak Spring 2018 UMass Dartmouth, Team S5-G7, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S5G7
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 1,068
