Ana içeriğe geç
Lenovo Thinkpad X201 Trackpad Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad X201 Trackpad Replacement, Trackpad: adım 1, 1 resimden 1.
    • Flip the laptop so that the rear side is visible.
    • Slide the switch located near the top of the laptop.
  2. Lenovo Thinkpad X201 Trackpad Replacement: adım 2, 2 resimden 1. Lenovo Thinkpad X201 Trackpad Replacement: adım 2, 2 resimden 2.
    • Slide out the battery near the top of the laptop.
  3. Lenovo Thinkpad X201 Trackpad Replacement: adım 3, 1 resimden 1.
    • Remove all screws found on the rear side of the laptop using a Phillips #00 screwdriver.
  4. Lenovo Thinkpad X201 Trackpad Replacement: adım 4, 2 resimden 1. Lenovo Thinkpad X201 Trackpad Replacement: adım 4, 2 resimden 2.
    • Push the silver bar on the side of the laptop downwards.
    • The trackpad will pop up.
  5. Lenovo Thinkpad X201 Trackpad Replacement: adım 5, 1 resimden 1.
    • If step 4 does not work, gently push the bar down while using your other hand to pull the trackpad up.
  6. Lenovo Thinkpad X201 Trackpad Replacement: adım 6, 3 resimden 1. Lenovo Thinkpad X201 Trackpad Replacement: adım 6, 3 resimden 2. Lenovo Thinkpad X201 Trackpad Replacement: adım 6, 3 resimden 3.
    • Remove the trackpad from the laptop.
Sonuç
Peter Gachuki
666 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G7, Peak Spring 2018 UMass Dartmouth, Team S5-G7, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S5G7
3 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
nice tutorial. thanks a lot
PiterYT - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 1,282
