Ana içeriğe geç
Lenovo Thinkpad x230 Bezel Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad x230 Bezel Replacement, Preparations: adım 1, 1 resimden 1.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
  2. Lenovo Thinkpad x230 Bezel Replacement, Locate the battery: adım 2, 1 resimden 1.
    • Flip the computer upside down.
    • The red rectangle shows the location of the battery.
  3. Lenovo Thinkpad x230 Bezel Replacement, Unlock the left switch: adım 3, 3 resimden 1. Lenovo Thinkpad x230 Bezel Replacement, Unlock the left switch: adım 3, 3 resimden 2. Lenovo Thinkpad x230 Bezel Replacement, Unlock the left switch: adım 3, 3 resimden 3.
    • Locate the two switches that lock the battery. Push the left-hand switch outward into the "unlocked" position.
  4. Lenovo Thinkpad x230 Bezel Replacement, Remove the battery: adım 4, 3 resimden 1. Lenovo Thinkpad x230 Bezel Replacement, Remove the battery: adım 4, 3 resimden 2. Lenovo Thinkpad x230 Bezel Replacement, Remove the battery: adım 4, 3 resimden 3.
    • Now push and hold the right clip to the right while using your other hand to gently slide the battery away from the computer.
  5. Lenovo Thinkpad x230 Bezel Replacement, Bezel: adım 5, 1 resimden 1.
    • Remove the plastic screw covers with an iFixit opening pick.
  6. Lenovo Thinkpad x230 Bezel Replacement: adım 6, 2 resimden 1. Lenovo Thinkpad x230 Bezel Replacement: adım 6, 2 resimden 2.
    • Remove the screws (0.4, 0.5 cm) from the bottom corners of the bezel using a Phillips #0 screwdriver.
  7. Lenovo Thinkpad x230 Bezel Replacement: adım 7, 3 resimden 1. Lenovo Thinkpad x230 Bezel Replacement: adım 7, 3 resimden 2. Lenovo Thinkpad x230 Bezel Replacement: adım 7, 3 resimden 3.
    • Carefully remove the plastic bezel cover using an iFixit opening pick.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Lino Virgen
996 İtibar
3 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 6-3, Bennett Fall 2016 Texas Tech, Team 6-3, Bennett Fall 2016 üyesi
TTU-BENNETT-F16S6G3
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 61
Her zaman: 6,043
