Ana içeriğe geç
Lenovo Thinkpad x230 Keyboard Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad x230 Keyboard Replacement, Preparations: adım 1, 1 resimden 1.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    Wouldn’t the risk of ESD damage be a bigger concern than electrical shock from a 20V/90W power supply? I mean, it would hurt, but it almost certainly wouldn’t kill you.
    Arie Copley-Radder - Yanıt
  2. Lenovo Thinkpad x230 Keyboard Replacement, Locate the battery: adım 2, 1 resimden 1.
    • Flip the computer upside down.
    • The red rectangle shows the location of the battery.
  3. Lenovo Thinkpad x230 Keyboard Replacement, Unlock the left switch: adım 3, 3 resimden 1. Lenovo Thinkpad x230 Keyboard Replacement, Unlock the left switch: adım 3, 3 resimden 2. Lenovo Thinkpad x230 Keyboard Replacement, Unlock the left switch: adım 3, 3 resimden 3.
    • Locate the two switches that lock the battery. Push the left-hand switch outward into the "unlocked" position.
  4. Lenovo Thinkpad x230 Keyboard Replacement, Remove the battery: adım 4, 3 resimden 1. Lenovo Thinkpad x230 Keyboard Replacement, Remove the battery: adım 4, 3 resimden 2. Lenovo Thinkpad x230 Keyboard Replacement, Remove the battery: adım 4, 3 resimden 3.
    • Now push and hold the right clip to the right while using your other hand to gently slide the battery away from the computer.
  5. Lenovo Thinkpad x230 Keyboard Replacement, remove screws: adım 5, 3 resimden 1. Lenovo Thinkpad x230 Keyboard Replacement, remove screws: adım 5, 3 resimden 2. Lenovo Thinkpad x230 Keyboard Replacement, remove screws: adım 5, 3 resimden 3.
    • There are 2 screws securing the keyboard. You can identify them by a small keyboard symbol (marked by an orange rectangle in the second picture).
    • Once you have located the two screws, remove them with a small Phillips screwdriver.
  6. Lenovo Thinkpad x230 Keyboard Replacement, remove strip above keyboard: adım 6, 3 resimden 1. Lenovo Thinkpad x230 Keyboard Replacement, remove strip above keyboard: adım 6, 3 resimden 2. Lenovo Thinkpad x230 Keyboard Replacement, remove strip above keyboard: adım 6, 3 resimden 3.
    • This step is not required.
    • Gently pull the strip out from the case.
    How do I reinsert this strip? When I insert the bottom clips first I can’t get the top ones in and vice versa. Also I don’t understand the mechanism of the top clips, why do they have the shape they do?
    Daan - Yanıt
    Wtf man? You made me broke that part! Shame on you for not deleted this useless step and misinforming us like this!
    Konman - Yanıt
  7. Lenovo Thinkpad x230 Keyboard Replacement, pop keyboard out of the casing: adım 7, 2 resimden 1. Lenovo Thinkpad x230 Keyboard Replacement, pop keyboard out of the casing: adım 7, 2 resimden 2.
    • Use a a plastic spudger (or a flat screwdriver) to push the keyboard towards the screen. This will pop the bottom of the keyboard out of the casing.
  8. Lenovo Thinkpad x230 Keyboard Replacement, lift keyboard: adım 8, 2 resimden 1. Lenovo Thinkpad x230 Keyboard Replacement, lift keyboard: adım 8, 2 resimden 2.
    • Carefully lift the keyboard so that you can access its connector.
  9. Lenovo Thinkpad x230 Keyboard Replacement, Unplug keyboard: adım 9, 2 resimden 1. Lenovo Thinkpad x230 Keyboard Replacement, Unplug keyboard: adım 9, 2 resimden 2.
    • Carefully unplug the connector by pulling.
    Don't pull on the orange band, as shown in the picture. For me it immediately ripped, even with only minimal force applied, thus ruining the wire.
    Alex Stahl - Yanıt
  10. Lenovo Thinkpad x230 Keyboard Replacement, done: adım 10, 1 resimden 1.
    • You are done - the keyboard is not connected to the laptop any more and can be replaced.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Johannes
1.061 İtibar
3 adet Kılavuz yazıldı
4Kılavuz Yorumları
Very good instructions. Really easy. Difficulty rather easy than moderate. Took me two minutes.
Carsten Mühlberg - Yanıt
How do I reinsert the strip above the keyboard? When I insert the bottom clips first I can’t get the top ones in and vice versa. Also I don’t understand the mechanism of the top clips, why do they have the shape they do?
Daan - Yanıt
Worked perfectly. It was easy enough that I could use a key ring screw driver
Chris Barry - Yanıt
Quisiera saber cómo reparar el teclado ya que está en corte y no me deja encender la laptop
Mario Sánchez Soroa - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 21
Son 30 gün: 105
Her zaman: 11,375
