Ana içeriğe geç
Lenovo Touch Y70-70 Battery Replacement
Neye ihtiyacın var
  1. Lenovo Touch Y70-70 Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Lenovo Touch Y70-70 Battery Replacement: adım 2, 1 resimden 1.
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Lenovo Touch Y70-70 Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Use the Phillips #0 screwdriver to unscrew the three screws holding the battery.
  4. Lenovo Touch Y70-70 Battery Replacement: adım 4, 1 resimden 1.
    • Use the Blunt Tweezers from the Tool Kit to disconnect the battery connections from the motherboard.
    • Remove the battery from the device.
Sonuç
To reassemble your device, follow the instructions on Step 3.
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 17
Her zaman: 1,033
