Ana içeriğe geç
Lenovo Touch Y70-70 Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo Touch Y70-70 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Flip the device so that the back cover is facing you.
    • Using the Phillips #0 screwdriver, remove 14 screws from the back of the device.
  2. Lenovo Touch Y70-70 Motherboard Replacement: adım 2, 3 resimden 1. Lenovo Touch Y70-70 Motherboard Replacement: adım 2, 3 resimden 2. Lenovo Touch Y70-70 Motherboard Replacement: adım 2, 3 resimden 3.
    • Using the Phillips #0 screwdriver, remove the three screws holding down the battery.
  3. Lenovo Touch Y70-70 Motherboard Replacement: adım 3, 2 resimden 1. Lenovo Touch Y70-70 Motherboard Replacement: adım 3, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove the metal reinforcement by removing the three screws.
  4. Lenovo Touch Y70-70 Motherboard Replacement: adım 4, 3 resimden 1. Lenovo Touch Y70-70 Motherboard Replacement: adım 4, 3 resimden 2. Lenovo Touch Y70-70 Motherboard Replacement: adım 4, 3 resimden 3.
    • Using the Phillips #0 screwdriver, carefully remove the three screws holding down the fan.
    • Detach the cables connecting the fan to the motherboard.
  5. Lenovo Touch Y70-70 Motherboard Replacement: adım 5, 2 resimden 1. Lenovo Touch Y70-70 Motherboard Replacement: adım 5, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove the six screws holding down the cooling unit.
  6. Lenovo Touch Y70-70 Motherboard Replacement: adım 6, 2 resimden 1. Lenovo Touch Y70-70 Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the Ethernet port by unscrewing the two screws holding it down.
  7. Lenovo Touch Y70-70 Motherboard Replacement: adım 7, 2 resimden 1. Lenovo Touch Y70-70 Motherboard Replacement: adım 7, 2 resimden 2.
    • Unplug the various cables attached to the motherboard using your fingers carefully.
    • Detach the cables using your fingers.
  8. Lenovo Touch Y70-70 Motherboard Replacement: adım 8, 3 resimden 1. Lenovo Touch Y70-70 Motherboard Replacement: adım 8, 3 resimden 2. Lenovo Touch Y70-70 Motherboard Replacement: adım 8, 3 resimden 3.
    • Finally, remove the six screws holding down the motherboard.
    • Remove the motherboard from the laptop.
Sonuç
Mohammed Motorwala
298 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G5, Harley Fall 2019 IUPUI, Team S2-G5, Harley Fall 2019 üyesi
IUPUI-HARLEY-F19S2G5
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 972
