Ana içeriğe geç
Lenovo V14-ADA Battery Replacement
Neye ihtiyacın var
  1. Lenovo V14-ADA Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop upside down.
  2. Lenovo V14-ADA Battery Replacement: adım 2, 1 resimden 1.
    • Remove all ten 5 mm screws from the back panel using a JIS #0 screwdriver.
  3. Lenovo V14-ADA Battery Replacement: adım 3, 2 resimden 1. Lenovo V14-ADA Battery Replacement: adım 3, 2 resimden 2.
    • Place the Jimmy in the small crack between the back panel and the keyboard and push down.
    • Repeat this until the panel pops off.
  4. Lenovo V14-ADA Battery Replacement, Battery: adım 4, 2 resimden 1. Lenovo V14-ADA Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Remove the four 3 mm screws surrounding the battery using a JIS #0 screwdriver.
    • Slightly pull on the black wire connector to unplug the battery.
    • Lift up the battery to remove it from the laptop.
Sonuç
Samaya Roukoz
253 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-2, Shaddix Spring 2024 UMass Dartmouth, Team 4-2, Shaddix Spring 2024 üyesi
UMASSD-SHADDIX-S24S4G2
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 119
