Giriş
If your Lenovo V14-ADA laptop (model 82C60072UE) is experiencing poor battery life and is not charging completely or will drain quickly when unplugged, use this replacement guide to help switch out the internal battery.
A good battery life is key when using a laptop; poor battery life or the battery quickly draining is not ideal because it can cause the laptop to not work efficiently.
Before beginning remove any power source from the laptop and make sure it is turned off, to ensure the most safe experience when replacing your battery.
Neye ihtiyacın var
Turn off the laptop.
Disconnect the charging cable from the laptop.
Flip the laptop upside down.
Remove the four 3 mm screws surrounding the battery using a JIS #0 screwdriver.
Slightly pull on the black wire connector to unplug the battery.
Lift up the battery to remove it from the laptop.
