Giriş
If your Lenovo V14-ADA (model 82C60072UE) has some dead pixels on the screen or the screen just wont work, you can use this guide to replace the LCD panel (screen). Dead pixels on the laptop are often displayed as a small black or white dot that can be caused by manufacturing defects or physical damage.
Before beginning, make sure the laptop is unplugged and turned off because the steps require disassembling parts of the laptop. Proceed with caution while completing the process in this guide.
Neye ihtiyacın var
Turn off the laptop.
Disconnect the charging cable from the laptop.
Flip the laptop upside down.
Remove the four 3 mm screws surrounding the battery using a JIS #0 screwdriver.
Slightly pull on the black wire connector to unplug the battery.
Lift up the battery to remove it from the laptop.
Remove the four 3 mm screws on the hinges on both sides of the back of the laptop.
Use the Jimmy to pop the surrounding screen bezel off.
Bir başkası bu kılavuzu tamamladı.
