Ana içeriğe geç
Lenovo V14-ARE Memory Upgrade/Replacement
Neye ihtiyacın var
  1. Lenovo V14-ARE Memory Upgrade/Replacement, Power down: adım 1, 1 resimden 1.
    • Hold down the power button for 5-10 seconds to shut it down.
    • It's not a good idea to have the computer on while messing with internal components.
    • Make sure not to lift up the screen or the computer will turn on again.
  2. Lenovo V14-ARE Memory Upgrade/Replacement, Unscrew the bottom case: adım 2, 1 resimden 1.
    • Take out the 10 Phillips screws
    • The 4 screws in red are much smaller than the 6 screws in orange. The orange screws are the same size
    • It probably will not shut right if you mix them up, I am yet to have mixed up the screws.
    • small screw
    • larger screw
  3. Lenovo V14-ARE Memory Upgrade/Replacement, Removing the bottom case: adım 3, 1 resimden 1.
    • Pry up from the edges using some sort of plastic pick, I used the one included in my ifixit toolkit
    • It was tough to remove the bottom case the first time, but be reasonable with your force so that you don't damage it
  4. Lenovo V14-ARE Memory Upgrade/Replacement, Removing the memory access panel: adım 4, 3 resimden 1. Lenovo V14-ARE Memory Upgrade/Replacement, Removing the memory access panel: adım 4, 3 resimden 2. Lenovo V14-ARE Memory Upgrade/Replacement, Removing the memory access panel: adım 4, 3 resimden 3.
    • The memory slot is hidden under the access panel (Picture 1)
    • There are little tabs that go along side the panel, just push down with something plastic like I did in the picture. (Picture 2)
    • When they're all released from the side of the panel you should be able to pull it up, revealing the memory slot. (Picture 3)
  5. Lenovo V14-ARE Memory Upgrade/Replacement, Installing Memory: adım 5, 3 resimden 1. Lenovo V14-ARE Memory Upgrade/Replacement, Installing Memory: adım 5, 3 resimden 2. Lenovo V14-ARE Memory Upgrade/Replacement, Installing Memory: adım 5, 3 resimden 3.
    • Line up the notches on the memory with the memory slot on the motherboard.
    • Then push the memory stick in, it should go up at an angle (Picture 2)
    • Then push down the memory stick, from the center. Push the memory till it clicks and the 2 tabs on the side are securing the memory. (Picture 3)
  6. Lenovo V14-ARE Memory Upgrade/Replacement, Putting the panel on, putting on the bottom case: adım 6, 3 resimden 1. Lenovo V14-ARE Memory Upgrade/Replacement, Putting the panel on, putting on the bottom case: adım 6, 3 resimden 2. Lenovo V14-ARE Memory Upgrade/Replacement, Putting the panel on, putting on the bottom case: adım 6, 3 resimden 3.
    • I put the panel back on for my computer. I'd imagine its optional but I did it just to be safe
    • The panel is put on by putting the panel in the ridge between the outside tabs(the ones used to release it) and the inside tabs (closest to the memory slot)
    • The panel is secured by pushing the outside tabs onto the panel (Picture 2)
    • To put on the bottom case, line it up using the hinge and the cutout for the hinge, then make sure the screws line up
    • Screw down the Phillips till they're tight be careful not to strip them.
Sonuç
Bir başkası bu kılavuzu tamamladı.
brady
160 İtibar
1 Kılavuz yazıldı
Bir Yorum
thanks bro i was kinda struggling with this one
Ahmad Muneeb - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 73
Her zaman: 2,200
