Ana içeriğe geç
Lenovo V14-IIL Screen Bezel Replacement
Neye ihtiyacın var
  1. Lenovo V14-IIL Screen Bezel Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo V14-IIL Screen Bezel Replacement, Back Panel: adım 1, 2 resimden 2.
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
    • Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
  2. Lenovo V14-IIL Screen Bezel Replacement: adım 2, 1 resimden 1.
    • Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo V14-IIL Screen Bezel Replacement: adım 3, 1 resimden 1.
    • Lift away the back panel and set it aside.
  4. Lenovo V14-IIL Screen Bezel Replacement, Display Assembly: adım 4, 2 resimden 1. Lenovo V14-IIL Screen Bezel Replacement, Display Assembly: adım 4, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the four 5 mm screws from the hinges of the laptop.
  5. Lenovo V14-IIL Screen Bezel Replacement: adım 5, 1 resimden 1.
    • Lift up the latch and gently pull the display cable free.
  6. Lenovo V14-IIL Screen Bezel Replacement: adım 6, 2 resimden 1. Lenovo V14-IIL Screen Bezel Replacement: adım 6, 2 resimden 2.
    • Using the spudger, disconnect the two wireless LAN cables (black and gray) from the wireless LAN card.
    • Remove the LAN cables from the three brackets on the fan.
  7. Lenovo V14-IIL Screen Bezel Replacement: adım 7, 1 resimden 1.
    • Ensure that all cables and hinges are detached.
    • Lift the display assembly away from the base.
  8. Lenovo V14-IIL Screen Bezel Replacement, Screen Bezel: adım 8, 2 resimden 1. Lenovo V14-IIL Screen Bezel Replacement, Screen Bezel: adım 8, 2 resimden 2.
    • Slide the cable hinge cover to the right.
    • Pull the part away from the screen.
  9. Lenovo V14-IIL Screen Bezel Replacement: adım 9, 2 resimden 1. Lenovo V14-IIL Screen Bezel Replacement: adım 9, 2 resimden 2.
    • Use the iFixit opening tool to separate the bezel panel.
    • Slide the opening tool all the way around to loosen the bezels on all sides.
    • You may need to use the tool to gently loosen the adhesive tape.
    • Lift away the bezel panel.
Sonuç
Kristen Gismondi
92.837 İtibar
241 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 59
